Api session items unitdatas
Revision as of 09:05, 3 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/unitdatas/
Edit items with events described at Api session event editor unitdataoverride.
Default Query:
https://engine.tygron.com/api/session/items/unitdatas/?f=JSON&token=API_TOKEN
Example Response:
  "active" : false,
  "colors" : [ {
    "argb" : -2694430
    "argb" : -5323066
    "argb" : -16169168
    "argb" : -14920883
    "argb" : -13550753
    "argb" : -14207929
    "argb" : -11710124
    "argb" : -10262421
    "argb" : -13619665
    "argb" : -14862524
    "argb" : -7529953
    "argb" : -10542299
  "fileName" : "motorcycle",
  "id" : 0,
  "isAlpha" : false,
  "name" : "Scooter",
  "particleEmitters" : [ ],
  "proximityWarningM" : -1.0,
  "regions" : [ ],
  "type" : "CAR",
  "version" : 1
  "active" : true,
  "colors" : [ {
    "argb" : -2694430
    "argb" : -5323066
  "fileName" : "plezierboot",
  "id" : 1,
  "isAlpha" : false,
  "name" : "Pleasure Boat",
  "regions" : [ ],
  "type" : "SHIP",
  "version" : 14
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/unitdatas/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/unitdatas/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/unitdatas/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/unitdatas/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/unitdatas/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/unitdatas/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/unitdatas/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/unitdatas/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/unitdatas/?f=ZIPSMILE&token=API_TOKEN
Api Model ParticleEmitterCoordinatePair
API Model description of ParticleEmitterCoordinatePair
Name Type Description
id int
offsetCoordinate double[]
particleEmitterID int Particle Emitter ID
Api Model Region
API Enumeration description of Region
Name Description
NORTH_AMERICA
NORTHWESTERN_EUROPE
ASIA
AFRICA
OTHER
Api Model TColor
API Model description of TColor
Api Model TrafficType
API Enumeration description of TrafficType
Name Description
CAR
VAN
TRUCK
BUS
BICYCLE
PEDESTRIAN
SHIP
TRAM
TRAIN
AIR
Api Model UnitData
API Model description of UnitData
active boolean
colors TColor[]
fileName String
id int
isAlpha boolean
name String
particleEmitters ParticleEmitterCoordinatePair[]
proximityWarningM double
regions Region[]
type TrafficType
version int
