Api session event participant parametric design plan
Revision as of 14:49, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/participant/parametric_design_plan/
Description: Parametric Design Plan
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
1 REQUIRED (PARAMETRIC_DESIGN Integer ID) Parametric Designs
2 REQUIRED (FunctionType or multiple values in array [a, b, c]) FunctionType[]
3 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
4 REQUIRED (MultiPolygon or multiple values in array [a, b, c]) MultiPolygon[][]
200 Integer[] (Integer array)
curl 'https://engine.tygron.com/api/session/event/participant/parametric_design_plan/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, "ROAD", 1, [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.762, 6799441.896 ], [ 658636.762, 6799451.896 ], [ 658646.762, 6799451.896 ], [ 658646.762, 6799441.896 ], [ 658636.762, 6799441.896 ] ] ] ]
Curl example multi item POST:
[ 1, 1, [ "ROAD", "WATER", "PARKING" ], [ 1, 2, 3 ], [ [ {
 "coordinates" : [ [ [ [ 658646.762, 6799441.896 ], [ 658646.762, 6799451.896 ], [ 658656.762, 6799451.896 ], [ 658656.762, 6799441.896 ], [ 658646.762, 6799441.896 ] ] ] ]
 "coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
 "coordinates" : [ [ [ [ 658656.762, 6799441.896 ], [ 658656.762, 6799451.896 ], [ 658666.762, 6799451.896 ], [ 658666.762, 6799441.896 ], [ 658656.762, 6799441.896 ] ] ] ]
JavaScript example POST:
 body: '[ 1, 1, "ROAD", 1, [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799441.896 ], [ 658636.762, 6799451.896 ], [ 658646.762, 6799451.896 ], [ 658646.762, 6799441.896 ], [ 658636.762, 6799441.896 ] ] ] ]} ] ]'
fetch("https://engine.tygron.com/api/session/event/participant/parametric_design_plan/", options)
