Api session event logic zone set attribute
API Endpoint: api/session/event/logic/zone_set_attribute/
Description: Set an Attribute for a Zone.
| 0 | REQUIRED | (ZONE Integer ID) | Zone ID | |
| 1 | REQUIRED | (String) | Valid Attribute name | |
| 2 | REQUIRED | (Floating point number) | Attribute value |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/zone_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Valid attribute name", 17 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/zone_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Valid attribute name", 84 ]'JavaScript example POST:
body: '[ 1, "Valid attribute name", 17 ]'
fetch("https://engine.tygron.com/api/session/event/logic/zone_set_attribute/", options)
