Api session event logic net cluster set load attributes
API Endpoint: api/session/event/logic/net_cluster_set_load_attributes/
Description: For each Net Load of a Net Cluster, set the values of the provided Attributes.
| 0 | REQUIRED | (NET_CLUSTER Integer ID) | Net Cluster ID | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Array with Attribute names | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Array with values |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Array with attribute name 1", 1.0 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ "Array with attribute name 1", "Array with attribute name 2", "Array with attribute name 3" ], [ 1.0, 2.0, 3.0 ] ]'JavaScript example POST:
body: '[ 1, "Array with attribute name 1", 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attributes/", options)
