Api session event logic net cluster set fraction connected
API Endpoint: api/session/event/logic/net_cluster_set_fraction_connected/
Description: Set the frAction of connected loads with a cluster.
| 0 | REQUIRED | (NET_CLUSTER Integer ID) | Net Cluster ID | |
| 1 | REQUIRED | (Floating point number) | FrAction connected, between 0 and 1 |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 70 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 54 ]'JavaScript example POST:
body: '[ 1, 70 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_cluster_set_fraction_connected/", options)
