Api session event logic measurement set sum
API Endpoint: api/session/event/logic/measurement_set_sum/
Description: Set a Measurement to add its base Overlays to itself.
| 0 | REQUIRED | (MEASUREMENT Integer ID) | Measurement ID | |
| 1 | REQUIRED | (true, false) | Add base Overlays | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/measurement_set_sum/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'JavaScript example POST:
body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_set_sum/", options)
