Api session event logic cinematic stakeholder start
Revision as of 14:49, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/cinematic_stakeholder_start/
Description: Start a Cinematic for a specific Stakeholder.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic ID
2 REQUIRED (true, false) Animate to Cinematic starting Point true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/cinematic_stakeholder_start/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST:
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/cinematic_stakeholder_start/", options)
