Api session event logic building set attribute
Revision as of 14:49, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/logic/building_set_attribute/
Description: Set Building Attribute to given number Value.
0 REQUIRED (BUILDING Integer ID) Building ID
2 REQUIRED (Floating point number) Value
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/building_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 5 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/building_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 76 ]'
JavaScript example POST:
 body: '[ 1, "Attribute Name", 5 ]'
fetch("https://engine.tygron.com/api/session/event/logic/building_set_attribute/", options)
