Api session event logic action log export
API Endpoint: api/session/event/logic/action_log_export/
Description: Export history of Actions taken by participants.
| 200 | byte[] (byte array) |
curl 'https://engine.tygron.com/api/session/event/logic/action_log_export/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''JavaScript example POST:
body: ''
fetch("https://engine.tygron.com/api/session/event/logic/action_log_export/", options)
