Api session event answer buildings demolish approval confirmed
API Endpoint: api/session/event/answer/buildings_demolish_approval_confirmed/
Description: Owner of Buildings confirms the continuation of the planned demolition
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder ID | |
| 1 | REQUIRED | (BUILDING Integer ID or multiple values in array [1, 2, 3]) | Building IDs | |
| 2 | REQUIRED | (true, false) | Confirms | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/answer/buildings_demolish_approval_confirmed/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/answer/buildings_demolish_approval_confirmed/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], true ]'JavaScript example POST:
body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/answer/buildings_demolish_approval_confirmed/", options)
