Api session event editor zoning set permitter
Revision as of 14:48, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorzoning/set_permitter/
Description: Set Permitter
0 REQUIRED (ZONE Integer ID) Zones
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editorzoning/set_permitter/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorzoning/set_permitter/", options)
