Api session event editor projectasset add texture
API Endpoint: api/session/event/editorprojectasset/add_texture/
Description: Upload new Textures as a Project Assets, auto rescaled to small, medium, large.
| 0 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Directory to upload to | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Filename. This should a simple file name, including extension | |
| 2 | REQUIRED | (byte or multiple values in array [a, b, c]) | File data |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorprojectasset/add_texture/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Directory to upload to 1", "Filename. This should a simple file name, including extension 1", [ 1, 2 ] ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorprojectasset/add_texture/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "Directory to upload to 1", "Directory to upload to 2", "Directory to upload to 3" ], [ "Filename. This should a simple file name, including extension 1", "Filename. This should a simple file name, including extension 2", "Filename. This should a simple file name, including extension 3" ], [ [ 1, 2 ], [ 3, 4 ], [ 5, 6 ] ] ]'JavaScript example POST:
body: '[ "Directory to upload to 1", "Filename. This should a simple file name, including extension 1", [ 1, 2 ] ]'
fetch("https://engine.tygron.com/api/session/event/editorprojectasset/add_texture/", options)
