Api session event editor projectasset add
Revision as of 14:47, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorprojectasset/add/
Description: Upload a new image as a Project Asset.
0 REQUIRED (String) Directory to upload to
1 REQUIRED (String) Filename. This should a simple file name, including extension
2 REQUIRED (byte or multiple values in array [a, b, c]) File data
200 Integer (Project Asset ID)
curl 'https://engine.tygron.com/api/session/event/editorprojectasset/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Directory to upload to", "Filename. This should a simple file name, including extension", 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorprojectasset/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Directory to upload to", "Filename. This should a simple file name, including extension", [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ "Directory to upload to", "Filename. This should a simple file name, including extension", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorprojectasset/add/", options)
