Api session event editor overlay set discharge method
Revision as of 14:47, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_discharge_method/
Description: Set Discharge Method
0 REQUIRED (OVERLAY Integer ID) Overlays
1 REQUIRED (Enumeration) DischargeMethod HEIGHT_MINIMA, AREAS or WATER_TERRAINS
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_discharge_method/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "HEIGHT_MINIMA" ]'
JavaScript example POST:
 body: '[ 1, "HEIGHT_MINIMA" ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_discharge_method/", options)
