Server Event
What is a Server Event
Main article: Events
Server events are events which are communicated to the server, and may affect all stakeholders. An example of this is the activation of a measure. These events may affect the 3D world and the indicator scores.
How do Server Events relate to the Tygron Engine
Server Events can be used in multiple locations in the Tygron Engine; as part of a measure, at the start of a level, as part of a larger event bundle in the action menu, etc. Server Events allow for events to be triggered during a session, which will result in a reaction from the server.
Different Server Event types
There are two flavors of Server Events: Logic Events and Player Events. The difference between these is that for Player Events at least one dedicated stakeholder needs to be assigned to the Server Event. A good example of this is the asking for or receiving of a money transfer (MONEY_TRANSFER_ASK & MONEY_TRANSFER_GIVE) as a Server Event. Logic Events do not require such a dedicated stakeholder and can be fired without one being assigned as property. A good example of this is the activation of a specific terrain type (TERRAIN_SET_ACTIVE) when creating a flooding as part of a measure.
Logic Event Types
Below is a list describing available Logic Server Event Types:
ACTION_MENU_SET_FUNCTION_AVAILABLE
Add or remove a function from a particular Action Menu
ACTION_MENU_SET_MEASURE_AVAILABLE
Add or remove a measure from a particular Action Menu
ACTION_MENU_SET_UPGRADE_AVAILABLE
Add or remove an upgrade from a particular Action Menu
BEAMER_SET_LAYER
Set the beamer layer to a specific overlay type
CINEMATIC_STAKEHOLDER_START
Start a cinematic for a specific stakeholder
CINEMATIC_STAKEHOLDER_STOP
Stop any cinematic for a specific stakeholder
LEVEL_SET_ACTIVE
MEASURE_UPDATE_CUSTOM
MESSAGE_ACTIVATE
MESSAGE_REVOKE
MESSAGE_RESET
SETTINGS_ALLOW_GAME_INTERACTION
SETTINGS_SET_MESSAGE_AUTO_RESPOND
SPECIAL_EFFECT_SET_ACTIVE
TERRAIN_SET_ACTIVE
TERRAIN_SET_POLYGON
TIME_SET_SIM_MULTIPLIER
UNIT_SET_ACTIVE
WEATHER_SET_DATA
ZOOMLEVEL_SET_ACTIVE
Player Event Types
ACTION_MENU_SET_ACTIVE
MEASURE_CANCEL_CONSTRUCTION
MEASURE_PLAN_CONSTRUCTION
MESSAGE_NEW
MONEY_TRANSFER_ASK
MONEY_TRANSFER_GIVE
SETTINGS_SET_ALLOWED_WATER_LEVEL_INCREASE
Adding Server Side Events to a project
Changing the properties of a Server Side Event in a project
