Api session event editor netcluster set fraction connected
Revision as of 14:46, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editornetcluster/set_fraction_connected/
Description: Set FrAction Connected
0 REQUIRED (NET_CLUSTER Integer ID) Net Clusters
1 OPTIONAL (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetcluster/set_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/set_fraction_connected/", options)
