Api session event editor measurement import
Revision as of 14:46, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editormeasurement/import/
Description: Import multiple Measurements
0 REQUIRED (GeometryCollection with crs: EPSG:3857) Measurements
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Measurement Names
2 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlays
204 No Content
curl 'https://engine.tygron.com/api/session/event/editormeasurement/import/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "Measurement Name 1", 1 ]
Curl example multi item POST:
 "geometries" : [ {
 "coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
}, [ "Measurement Name 1", "Measurement Name 2", "Measurement Name 3" ], [ 1, 2, 3 ] ]
JavaScript example POST:
 body: '[ { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, "Measurement Name 1", 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasurement/import/?crs=3857", options)
