Api session event editor measure import buildings
API Endpoint: api/session/event/editormeasure/import_buildings/
Description: Import Measure Building Collection
| 0 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | Collection of Building geometries | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Building Names | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attribute Names | |
| 3 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | Attribute Values | |
| 4 | REQUIRED | (FUNCTION Integer ID or multiple values in array [1, 2, 3]) | Functions | |
| 5 | OPTIONAL | (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) | Owners (optional) | |
| 6 | OPTIONAL | (MEASURE Integer ID) | Set for existing Measure ID (optional) | |
| 7 | OPTIONAL | (Floating point number) | Buffer for Points and Lines to make Polygons (optional) | |
| 8 | OPTIONAL | (SOURCE Integer ID) | Source (optional) |
curl 'https://engine.tygron.com/api/session/event/editormeasure/import_buildings/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
"type" : "GeometryCollection",
"geometries" : [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, "Building Name 1", "Attribute Name 1", [ 1.0, 2.0 ], 1 ]
'Curl example multi item POST:
"geometries" : [ {
"coordinates" : [ [ [ [ 658646.762, 6799451.896 ], [ 658646.762, 6799461.896 ], [ 658656.762, 6799461.896 ], [ 658656.762, 6799451.896 ], [ 658646.762, 6799451.896 ] ] ] ]
"coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
}, [ "Building Name 1", "Building Name 2", "Building Name 3" ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], [ 1, 2, 3 ] ]
'JavaScript example POST:
body: '[ { "type" : "GeometryCollection", "geometries" : [ { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ] } ]}, "Building Name 1", "Attribute Name 1", [ 1.0, 2.0 ], 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/import_buildings/?crs=3857", options)
