Api session event editor geolink set function
API Endpoint: api/session/event/editorgeolink/set_function/
Description: Set Function
| 0 | REQUIRED | (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) | Geo Links | |
| 1 | REQUIRED | (FUNCTION Integer ID or multiple values in array [1, 2, 3]) | Functions |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorgeolink/set_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeolink/set_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorgeolink/set_function/", options)
