Api session event editor functionoverride set description
API Endpoint: api/session/event/editorfunctionoverride/set_description/
Description: Set Description
| 0 | REQUIRED | (FUNCTION_OVERRIDE Integer ID) | Function Overrides | |
| 1 | REQUIRED | (String) | String |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorfunctionoverride/set_description/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Text" ]'JavaScript example POST:
body: '[ 1, "Text" ]'
fetch("https://engine.tygron.com/api/session/event/editorfunctionoverride/set_description/", options)
