Api session event editor functionoverride reset assets
Revision as of 14:45, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorfunctionoverride/reset_assets/
Description: Reset Assets
0 REQUIRED (FUNCTION Integer ID) Functions
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorfunctionoverride/reset_assets/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorfunctionoverride/reset_assets/", options)
