Api session event editor eventbundle remove
API Endpoint: api/session/event/editoreventbundle/remove/
Description: Remove existing Event Bundle
| 0 | REQUIRED | (EVENT_BUNDLE Integer ID or multiple values in array [1, 2, 3]) | Event Bundles |
| 200 | Boolean (True when at least one item was removed) |
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoreventbundle/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editoreventbundle/remove/", options)
