Api session event editor cinematic set keypoint paused
Revision as of 14:44, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorcinematic/set_keypoint_paused/
Description: Set KeyPoint Paused
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic Datas
1 REQUIRED (Integer number) Integer
2 REQUIRED (true, false) Boolean true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_paused/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST:
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_paused/", options)
