Api session event editor building set decals
API Endpoint: api/session/event/editorbuilding/set_decals/
Description: Set Decals
| 0 | REQUIRED | (BUILDING Integer ID) | Buildings | |
| 1 | REQUIRED | (Enumeration) | FaceType | BASEMENT, EXTRA, GROUND, ROOF or TOP |
| 2 | OPTIONAL | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | float[] |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_decals/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "BASEMENT" ]'JavaScript example POST:
body: '[ 1, "BASEMENT" ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/set_decals/", options)
