Api session event editor building generate rotation angles
Revision as of 14:44, 2 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorbuilding/generate_rotation_angles/
Description: Calculation a rotation angle for Buildings having the identifying Attribute Polygons, optionally only for specified Buildings.
0 REQUIRED (String) Identifying Attribute
1 REQUIRED (String) Rotation Attribute
2 OPTIONAL (BUILDING Integer ID or multiple values in array [1, 2, 3]) Specific BuildingIDs only (optional)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorbuilding/generate_rotation_angles/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Identifying attribute", "Rotation attribute" ]'
JavaScript example POST:
 body: '[ "Identifying attribute", "Rotation attribute" ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/generate_rotation_angles/", options)
