Api session event editor building add section
API Endpoint: api/session/event/editorbuilding/add_section/
Description: Add Section
| 0 | REQUIRED | (BUILDING Integer ID or multiple values in array [1, 2, 3]) | Buildings |
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add_section/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add_section/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/add_section/", options)
