Api session event editor update
API Endpoint: api/session/event/editor/update/
Description: Calculate all active Overlays, Indicators, Panels and Triggers and wait for the update. Note: for long-running calculations use: set_scheduled_update/ to schedule an update.
| 0 | OPTIONAL | (true, false) | Reset all X-Queries (optional) |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/session/event/editor/update/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''JavaScript example POST:
body: ''
fetch("https://engine.tygron.com/api/session/event/editor/update/", options)
