Api session event participant popup answer with date
API Endpoint: api/session/event/participant/popup_answer_with_date/
Description: Stakeholder answers a Popup with an additional date.
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder ID | |
| 1 | REQUIRED | (POPUP Integer ID) | Message ID | |
| 2 | REQUIRED | (Integer number) | Answer (Panel) ID | |
| 3 | REQUIRED | (Integer number) | Date in milliseconds long from epoch |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/participant/popup_answer_with_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1, 5 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/participant/popup_answer_with_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1, 17 ]'JavaScript example POST:
body: '[ 1, 1, 1, 5 ]'
fetch("https://engine.tygron.com/api/session/event/participant/popup_answer_with_date/", options)
