Api session event participant building plan construction
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/participant/building_plan_construction/ Description: Plan a new Building in the MAQUETTE map. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholder ID | |- |1 |REQUIRED |(FUNCTION Integer ID) |Function ID | |- |2 |REQUIRED |(Integer number) |Amount of floors | |- |3 |REQUIRED |(MultiPolygon with crs: EPSG:3857) |MultiPolygon describing...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (FUNCTION Integer ID) Function ID
2 REQUIRED (Integer number) Amount of floors
3 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon describing the build contour
200 Integer (Action Log ID)
curl 'https://engine.tygron.com/api/session/event/participant/building_plan_construction/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, 1, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
JavaScript example POST:
 body: '[ 1, 1, 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]} ]'
fetch("https://engine.tygron.com/api/session/event/participant/building_plan_construction/?crs=3857", options)
