Api session event logic zones set attributes
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/zones_set_attributes/ Description: Set attributes to values for Zone. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(ZONE Integer ID or multiple values in array [1, 2, 3]) |Zone IDs | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Valid attribute names | |- |2 |REQUIRED |(Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4...")
0 REQUIRED (ZONE Integer ID or multiple values in array [1, 2, 3]) Zone IDs
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Valid attribute names
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Attribute values
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/zones_set_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Valid attribute name 1", [ 1.0, 2.0 ] ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/zones_set_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Valid attribute name 1", "Valid attribute name 2", "Valid attribute name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ] ]'
JavaScript example POST:
 body: '[ 1, "Valid attribute name 1", [ 1.0, 2.0 ] ]'
fetch("https://engine.tygron.com/api/session/event/logic/zones_set_attributes/", options)
