Api session event logic undo last building action
API Endpoint: api/session/event/logic/undo_last_building_action/
Description: Undo the last Building action of a Stakeholder.
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder ID |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/undo_last_building_action/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/logic/undo_last_building_action/", options)
