Api session event logic net cluster set load attributes
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/net_cluster_set_load_attributes/ Description: For each Net Load of a Net Cluster, set the values of the provided attributes. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(NET_CLUSTER Integer ID) |Net Cluster ID | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Array with attribute names | |- |2 |REQUIRED |(Floating point number or multiple values in array [1.0, 2...")
0 REQUIRED (NET_CLUSTER Integer ID) Net Cluster ID
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Array with attribute names
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Array with values
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Array with attribute name 1", 1.0 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ "Array with attribute name 1", "Array with attribute name 2", "Array with attribute name 3" ], [ 1.0, 2.0, 3.0 ] ]'
JavaScript example POST:
 body: '[ 1, "Array with attribute name 1", 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_cluster_set_load_attributes/", options)
