Api session event logic net cluster set fraction connected
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/net_cluster_set_fraction_connected/ Description: Set the fraction of connected loads with a cluster. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(NET_CLUSTER Integer ID) |Net Cluster ID | |- |1 |REQUIRED |(Floating point number) |Fraction connected, between 0 and 1 | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Ex...")
0 REQUIRED (NET_CLUSTER Integer ID) Net Cluster ID
1 REQUIRED (Floating point number) Fraction connected, between 0 and 1
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 61 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 24 ]'
JavaScript example POST:
 body: '[ 1, 61 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_cluster_set_fraction_connected/", options)
