Api session event logic money transfer add
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/money_transfer_add/ Description: Create a new Money Transfer between two Stakeholder. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholder From ID | |- |1 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholder To ID | |- |2 |REQUIRED |(Enumeration) |Money transfer Type |LAND, SUBSIDY or TRANSFER |- |3 |REQUIRED |(String) |Provided motivation | |- |4 |REQUI...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder From ID
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder To ID
2 REQUIRED (Enumeration) Money transfer Type LAND, SUBSIDY or TRANSFER
3 REQUIRED (String) Provided motivation
4 REQUIRED (Floating point number) Transfer amount
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/money_transfer_add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "SUBSIDY", "Provided motivation", 82 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/money_transfer_add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "SUBSIDY", "Provided motivation", 23 ]'
JavaScript example POST:
 body: '[ 1, 1, "SUBSIDY", "Provided motivation", 82 ]'
fetch("https://engine.tygron.com/api/session/event/logic/money_transfer_add/", options)
