Api session event logic measurement set overlays
API Endpoint: api/session/event/logic/measurement_set_overlays/
Description: Set base Overlay for an existing Measurement.
| 0 | REQUIRED | (MEASUREMENT Integer ID) | Measurement ID | |
| 1 | REQUIRED | (OVERLAY Integer ID or multiple values in array [1, 2, 3]) | Overlay ID |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/measurement_set_overlays/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/measurement_set_overlays/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_set_overlays/", options)
