Api session event logic measurement save
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/measurement_save/ Description: Save a Measurement. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(MEASUREMENT Integer ID) |Measurement ID | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Curl example POST: <syntaxhighlight lang="text" copy>curl 'https://engine.tygron.com/api/session/event/logic/me...")
0 REQUIRED (MEASUREMENT Integer ID) Measurement ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/measurement_save/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/logic/measurement_save/", options)
