Api session event logic cinematic stakeholder start
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/cinematic_stakeholder_start/ Description: Start a Cinematic for a specific Stakeholder. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholder ID | |- |1 |REQUIRED |(CINEMATIC_DATA Integer ID) |Cinematic ID | |- |2 |REQUIRED |(true, false) |Animate to Cinematic starting point |true or false |} ===Response Codes=== {|class=wikitable !Response Code:...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic ID
2 REQUIRED (true, false) Animate to Cinematic starting point true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/cinematic_stakeholder_start/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST:
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/cinematic_stakeholder_start/", options)
