Api session event logic building set attributes
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/building_set_attributes/ Description: Per entry in the array, set the values of the attribute for the Building. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(BUILDING Integer ID or multiple values in array [1, 2, 3]) |Array of Building IDs | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Attribute Names | |- |2 |REQUIRED |(Floating point number or multiple values in...")
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Array of Building IDs
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute Names
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Array of values
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/building_set_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name 1", [ 1.0, 2.0 ] ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/building_set_attributes/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ] ]'
JavaScript example POST:
 body: '[ 1, "Attribute Name 1", [ 1.0, 2.0 ] ]'
fetch("https://engine.tygron.com/api/session/event/logic/building_set_attributes/", options)
