Api session event logic building set attribute
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/building_set_attribute/ Description: Set Building Attribute to given number Value. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(BUILDING Integer ID) |Building ID | |- |1 |REQUIRED |(String) |Attribute Name | |- |2 |REQUIRED |(Floating point number) |Value | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example...")
0 REQUIRED (BUILDING Integer ID) Building ID
2 REQUIRED (Floating point number) Value
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/building_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 8 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/building_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 51 ]'
JavaScript example POST:
 body: '[ 1, "Attribute Name", 8 ]'
fetch("https://engine.tygron.com/api/session/event/logic/building_set_attribute/", options)
