Api session event logic action menu set function available
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/logic/action_menu_set_function_available/ Description: Add or remove a Function from a particular Action Menu. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(ACTION_MENU Integer ID) |Action Menu ID | |- |1 |REQUIRED |(FUNCTION Integer ID) |Function ID | |- |2 |REQUIRED |(true, false) |Available |true or false |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204...")
0 REQUIRED (ACTION_MENU Integer ID) Action Menu ID
1 REQUIRED (FUNCTION Integer ID) Function ID
2 REQUIRED (true, false) Available true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/action_menu_set_function_available/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST:
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/logic/action_menu_set_function_available/", options)
