Api session event answer upgrade zoning permit confirmed
API Endpoint: api/session/event/answer/upgrade_zoning_permit_confirmed/
Description: Stakeholder's upgrade has received a zoning permit
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder ID | |
| 1 | REQUIRED | (BUILDING Integer ID) | Building ID |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/answer/upgrade_zoning_permit_confirmed/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/answer/upgrade_zoning_permit_confirmed/", options)
