Api session event answer measure zoning permit denied
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/answer/measure_zoning_permit_denied/ Description: Zoning plan permitter denied the Measure {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholder ID | |- |1 |REQUIRED |(MEASURE Integer ID) |Measure ID | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Curl example POST: <s...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (MEASURE Integer ID) Measure ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/answer/measure_zoning_permit_denied/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/answer/measure_zoning_permit_denied/", options)
