Api session event answer measure construction zoning approval confirm
API Endpoint: api/session/event/answer/measure_construction_zoning_approval_confirm/
Description: Owner confirms zoning permit for Measure
| 0 | REQUIRED | (MEASURE Integer ID) | Measure ID |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/answer/measure_construction_zoning_approval_confirm/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/answer/measure_construction_zoning_approval_confirm/", options)
