Api session event answer measure construction approval
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/answer/measure_construction_approval/ Description: Stakeholder approves construction of Measure {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholder ID | |- |1 |REQUIRED |(MEASURE Integer ID) |Measure ID | |- |2 |REQUIRED |(STAKEHOLDER Integer ID) |Approving Stakeholder ID | |- |3 |REQUIRED |(true, false) |Approves |true or false |} ===Response Codes==...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (MEASURE Integer ID) Measure ID
2 REQUIRED (STAKEHOLDER Integer ID) Approving Stakeholder ID
3 REQUIRED (true, false) Approves true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/answer/measure_construction_approval/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1, true ]'
JavaScript example POST:
 body: '[ 1, 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/answer/measure_construction_approval/", options)
