Api session event answer building demolish approval
API Endpoint: api/session/event/answer/building_demolish_approval/
Description: Stakeholder approves demolition of Building
| 0 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder ID | |
| 1 | REQUIRED | (BUILDING Integer ID) | Building ID | |
| 2 | REQUIRED | (true, false) | Approves | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/answer/building_demolish_approval/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'JavaScript example POST:
body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/answer/building_demolish_approval/", options)
