Api session event answer building ask construction date
Revision as of 09:25, 1 June 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Endpoint: api/session/event/answer/building_ask_construction_date/ Description: Stakeholder has planned the construction of a particular Building for a particular date stored in a Popup {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholder ID | |- |1 |REQUIRED |(BUILDING Integer ID) |Building ID | |- |2 |REQUIRED |(POPUP Integer ID) |Popup ID | |} ===Response Codes=== {|class=wi...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (BUILDING Integer ID) Building ID
2 REQUIRED (POPUP Integer ID) Popup ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/answer/building_ask_construction_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/answer/building_ask_construction_date/", options)
