Api session items measurements
Revision as of 12:14, 29 May 2026 by Frank@tygron.nl (talk | contribs)
Api session items Measurement Endpoint: /api/session/items/measurements/
Edit items with events described at Api session event editor measurement.
Default Query:
https://engine.tygron.com/api/session/items/measurements/?f=JSON&token=API_TOKEN
Example Response:
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/measurements/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/measurements/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/measurements/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/measurements/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/measurements/?crs=LOCAL&token=API_TOKEN
bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/measurements/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/measurements-foo/?crs=3857&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/measurements/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/measurements/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/measurements/?f=HTML&token=API_TOKEN
JSON:
GEOJSON:
https://engine.tygron.com/api/session/items/measurements/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/measurements/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/measurements/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/measurements/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/measurements/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/measurements/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/measurements/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/measurements/?f=ZIPSMILE&token=API_TOKEN
Api Model ItemMeasurement
API Model description of ItemMeasurement
Name Type Description
id int
itemID int
key String
mapLink MapLink
maqMax double
maqMin double
max double
min double
name String
overlayIDs int[] Overlay ID
overlayMaqValues Map<int,float[]>
overlayValues Map<int,float[]>
point Point
save boolean
sourceIDs int[] Source ID
sum boolean
version int
Api Model LineMeasurement
API Model description of LineMeasurement
distances double[]
id int
lineSegment LineSegment
lineString LineString
maqMax double
maqMin double
maqValues Map<int,java.util.ArrayList<float[]>>
max double
min double
name String
save boolean
sum boolean
values Map<int,java.util.ArrayList<float[]>>
version int
Api Model LineString
API Model description of LineString
Api Model Measurement
API Model description of Measurement
id int
name String
save boolean
sum boolean
version int
Api Model Point
API Model description of Point
type String Point
coordinates double[] x, y, (optional) z
Api Model PointMeasurement
API Model description of PointMeasurement
id int
maqMax double
maqMin double
max double
min double
name String
point Point
save boolean
sum boolean
version int
