Api session items heights
Api session items Height sector Endpoint: /api/session/items/heights/
Edit items with events described at Api session event editor map.
Default Query:
https://engine.tygron.com/api/session/items/heights/?f=JSON&token=API_TOKENExample Response:
"id" : 0,
"name" : "1",
"pointAreaM2" : 16.0,
"pointWidth" : [ 125, 0 ],
"sourceIDs" : [ 8 ],
"square" : {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 657093.832562376, 6800274.005242179 ], [ 657093.832562376, 6799461.8964563515 ], [ 657905.9006092999, 6799461.8964563515 ], [ 657905.9006092999, 6800274.005242179 ], [ 657093.832562376, 6800274.005242179 ] ] ] ]
"version" : 6
"id" : 1,
"name" : "2",
"square" : {
"coordinates" : [ [ [ [ 657905.9006092999, 6800274.005242179 ], [ 657905.9006092999, 6799461.8964563515 ], [ 658717.9686562237, 6799461.8964563515 ], [ 658717.9686562237, 6800274.005242179 ], [ 657905.9006092999, 6800274.005242179 ] ] ] ]
"version" : 3
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/heights/?version=100&token=API_TOKENPseudo-Mercator:
https://engine.tygron.com/api/session/items/heights/?crs=3857&token=API_TOKENDegrees:
https://engine.tygron.com/api/session/items/heights/?crs=4326&token=API_TOKENAmersfoort / RD New:
https://engine.tygron.com/api/session/items/heights/?crs=28992&token=API_TOKENLocal Coordinates:
https://engine.tygron.com/api/session/items/heights/?crs=LOCAL&token=API_TOKENbbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/heights/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKENFOO:
https://engine.tygron.com/api/session/items/heights-foo/?crs=3857&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/heights/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/heights/size/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/heights/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/heights/?f=JSON&token=API_TOKENGEOJSON:
https://engine.tygron.com/api/session/items/heights/?f=GEOJSON&token=API_TOKENGPKG:
https://engine.tygron.com/api/session/items/heights/?f=GPKG&token=API_TOKENDXF:
https://engine.tygron.com/api/session/items/heights/?f=DXF&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/heights/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/heights/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/heights/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/heights/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/heights/?f=ZIPSMILE&token=API_TOKENApi Model GeometryCollection
API Model description of GeometryCollection
| Name | Type | Description |
Api Model HeightSector
API Model description of HeightSector
| changed | Boolean | |
| envelope | Envelope | |
| id | int | |
| name | String | |
| pointAreaM2 | double | |
| pointWidth | int[] | |
| sourceIDs | int[] | Source ID |
| square | MultiPolygon | |
| version | int |
Api Model MultiPolygon
API Model description of MultiPolygon
| type | String | MultiPolygon |
| coordinates | double[][][][] | array of polygons; polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z] |
