Api session items specialoptions
Revision as of 12:09, 29 May 2026 by Frank@tygron.nl (talk | contribs)
Api session items Special Options Endpoint: /api/session/items/specialoptions/
Default Query:
https://engine.tygron.com/api/session/items/specialoptions/?f=JSON&token=API_TOKEN
Example Response:
  "defaults" : [ "MUNICIPALITY", "HOUSING_CORPORATION", "PROJECT_DEVELOPER", "FARMER", "EDUCATION", "HEALTHCARE", "CIVILIAN", "COMPANY" ],
  "description" : "Select the land you wish to buy.",
  "id" : 0,
  "imageName" : "buy_land.png",
  "name" : "Buy land",
  "version" : 4
  "description" : "Select the land you would like to sell to another stakeholder.",
  "id" : 1,
  "imageName" : "sell_land.png",
  "name" : "Sell land",
  "version" : 5
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/specialoptions/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/specialoptions/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/specialoptions/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/specialoptions/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/specialoptions/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/specialoptions/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/specialoptions/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/specialoptions/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/specialoptions/?f=ZIPSMILE&token=API_TOKEN
Api Model SpecialOption
API Model description of SpecialOption
Name Type Description
defaults Type[]
description String
id int
imageName String
name String
version int
Api Model Type (Stakeholder)
API Enumeration description of Type
Name Description
CIVILIAN
COMPANY
EDUCATION
EXPERT
FARMER
HEALTHCARE
HOUSING_CORPORATION
MUNICIPALITY
MEDIA
PROJECT_DEVELOPER
UTILITY_CORPORATION
WATER_AUTHORITY
OTHER_AUTHORITY
OTHER
