Api session items popups
Revision as of 12:09, 29 May 2026 by Frank@tygron.nl (talk | contribs)
Api session items Popup Endpoint: /api/session/items/popups/
Default Query:
https://engine.tygron.com/api/session/items/popups/?f=JSON&token=API_TOKEN
Example Response:
  "answers" : [ ],
  "calendar" : null,
  "color" : {
    "argb" : -6704129
  "id" : 0,
  "imageType" : "RECEIVE_REQUEST",
  "linkID" : 1,
  "linkType" : "PANELS",
  "modelDataID" : -1,
  "modelType" : "DECLINED",
  "name" : " 1",
  "opensAutomatically" : false,
  "overrideAttention" : true,
  "point" : {
    "type" : "Point",
    "coordinates" : [ 658907.9990757483, 6798948.801026824, 36.557 ]
  "polygons" : null,
  "scale" : 1.0,
  "text" : "",
  "title" : "Text Panel",
  "type" : "INTERACTION",
  "version" : 3,
  "visibleForStakeholderIDs" : [ 0, 1, 2, 3, 4, 5 ],
  "visibleTimeframe" : 0
  "answers" : [ ],
  "calendar" : null,
  "color" : {
    "argb" : -19610
  "id" : 1,
  "linkID" : 2,
  "modelDataID" : -1,
  "modelType" : "ELEVATION",
  "name" : " 2",
  "point" : {
    "type" : "Point",
    "coordinates" : [ 659100.8960954784, 6799034.555303296, 80.804 ]
  "polygons" : null,
  "scale" : 1.0,
  "text" : "",
  "title" : "Text Panel (2)",
  "version" : 6,
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/popups/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/popups/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/popups/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/popups/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/popups/?crs=LOCAL&token=API_TOKEN
bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/popups/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/popups-foo/?crs=3857&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/popups/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/popups/size/?token=API_TOKEN
Popups (GeoJSON):
https://engine.tygron.com/web/popups.geojson?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/popups/?f=HTML&token=API_TOKEN
JSON:
GEOJSON:
https://engine.tygron.com/api/session/items/popups/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/popups/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/popups/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/popups/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/popups/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/popups/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/popups/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/popups/?f=ZIPSMILE&token=API_TOKEN
Api Model Answer
API Model description of Answer
Name Type Description
clientEvents CodedEvent[]
contents String
events CodedEvent[]
id int
selected boolean
Api Model CodedEvent
API Model description of CodedEvent
id int
parameters Object[]
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model MultiPolygon
API Model description of MultiPolygon
type String MultiPolygon
coordinates double[][][][] array of polygons; polygon is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z]
Api Model Point
API Model description of Point
type String Point
coordinates double[] x, y, (optional) z
Api Model PopupData
API Model description of PopupData
answers Answer[]
calendar long
color TColor
id int
imageType PopupImageType
linkID int
linkType MapLink
modelDataID int Model Data ID
modelType PopupModelType
name String
opensAutomatically boolean
overrideAttention Boolean
point Point
polygons MultiPolygon
scale double
text String
title String
type Type
version int
visibleForStakeholderIDs int[] Stakeholder ID
visibleTimeframe int
Api Model PopupImageType
API Enumeration description of PopupImageType
Name Description
PICK_DATE
REQUEST_PERMIT
RECEIVE_REQUEST
WAITING
DECLINE
APPROVE
WAIT_BUILD
WAIT_DEMOLISH
BUILD_PROGRESS
DEMOLISH_PROGRESS
BUY_LAND
SELL_LAND
Api Model PopupModelType
API Enumeration description of PopupModelType
Name Description
APPROVED
ARROW
BUY
CONNECT_ON
CONNECT_OFF
CONSTRUCTING
ELEVATION
DECLINED
DEMOLISHING
WAITING
QUESTION_MARK
TRAFFIC_NOISE
WATER_CRANE
WATER_ARROW
WATER_WEIR
LIGHT_BULB
LIGHTNING
BAR_CHART
EXCLAMATION
Api Model TColor
API Model description of TColor
Api Model Type (PopupData)
API Enumeration description of Type
Name Description
STAKEHOLDER_STANDARD
INTERACTION
INTERACTION_WITH_DATE
INFORMATION
LABEL
